[postgis-tickets] [PostGIS] #2801: Dedicated docbook xml file for pagc address_parser
PostGIS trac at osgeo.org
Sat Jul 5 00:31:05 PDT 2014
 Reporter:  robe                 |       Owner:  robe
     Type:  enhancement          |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.2.0
Component:  pagc_address_parser  |     Version:  trunk
 Keywords:  documentation        |
Comment(by robe):
 okay started this.  I made some mistakes because I had diabled my docbok
 validator.
 So revisions are r12727 - r12730
 I made it as a separate chapter so we can add multiple sections.  Once
 built -- it should appear right after topology.  What is left to do
 1) Flesh out the about this
 2) Examples for standardize_address function
 3) add the parse_address function to functions section
 4) Add section for table lex, gaz, rules and what the different fields and
 elements mean.  In particular the rules table which is non-obvious but I
 assume most of the content from here can be used -
 http://www.pagcgeo.org/docs/html/pagc-11.html#ss11.3
 Note I did also add section type which has the stdaddr and for each column
 what the token number is in rules.
 This I lifted off largely from
 http://www.pagcgeo.org/docs/html/pagc-12.html#ss12.2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2801#comment:1>
