[postgis-tickets] [PostGIS] #2822: Slow _add_raster_constraint_extent
trac at osgeo.org
Mon Jul 7 08:58:26 PDT 2014
Reporter: strk | Owner: dustymugs
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Resolution: fixed | Keywords: history
Comment(by strk):
Quick test on a table with 19208 rows with 256x256 tiles brings down the
_add_raster_constraint_extent time from ~23 seconds to ~15 seconds.
select st_envelope(rast) takes ~7.5 seconds, so the math is one go to
compute max extent and another go to check the constraint, which makes
indeed those ~15 seconds.
Now I wonder if st_envelope could be made faster (does it detoast a single
slice of the toast already?)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2822#comment:8>
