[postgis-tickets] [PostGIS] #2825: ST_Intersection broken with Z coordinates
trac at osgeo.org
Mon Jul 7 11:56:02 PDT 2014
Reporter: TBL | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.4
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by TBL):
You mean something like this?
Original query with a single line:
with linestring as (
select st_makeline(
st_geomfromtext('LINESTRING Z (-1 -1 0,-0.5 -0.5 1,0 0 2,0.5 0.5 3,1 1
4,1.5 1.5 5)', 4326),
st_geomfromtext('LINESTRING Z (2 2 6,1.5 1.5 7,1 1 8,0.5 0.5 9,0 0
10)', 4326)
) as geom
polygon as (select ST_GeomFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))',
4326) as geom)
select st_astext(st_intersection(linestring.geom, polygon.geom)) from
linestring, polygon
Result
"MULTILINESTRING Z ((0 0 6,0.5 0.5 6),(0.5 0.5 6,1 1 6))"
Query with a multilinestring:
select st_collect(
10)', 4326)
) as geom
4326) as geom)
linestring, polygon
Result as above:
And with two distinct linestrings:
select
(select st_geomfromtext('LINESTRING Z (-1 -1 0,-0.5 -0.5 1,0 0 2,0.5
0.5 3,1 1 4,1.5 1.5 5)', 4326)) as geom
union all
(select st_geomfromtext('LINESTRING Z (2 2 6,1.5 1.5 7,1 1 8,0.5 0.5
9,0 0 10)', 4326))
4326) as geom)
linestring, polygon
Result is as expected:
"LINESTRING Z (0 0 2,0.5 0.5 3,1 1 4)"
"LINESTRING Z (1 1 8,0.5 0.5 9,0 0 10)"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2825#comment:6>
