[postgis-tickets] [PostGIS] #2826: PostGIS 2.1 failing on 9.0 raster test
trac at osgeo.org
Mon Jul 7 16:27:22 PDT 2014
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.4
Component: raster | Version: 2.1.x
Keywords: |
Debbie 9.0 regress on 2.1 is failing. I'll try running again
I'm suspecting
r12742 or r12745 is the culprit.
Creating database 'postgis_reg'
Loading PostGIS into 'postgis_reg'
/var/lib/jenkins/workspace/postgis/branches/2.1/regress/00-regress-
install/share/contrib/postgis/postgis.sql
install/share/contrib/postgis/postgis_comments.sql
Loading Raster into 'postgis_reg'
install/share/contrib/postgis/rtpostgis.sql
Error encountered loading
install/share/contrib/postgis/rtpostgis.sql, see
/var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.0w64/regress_log for
details
make[3]: *** [check] Error 9
make[3]: Leaving directory
`/var/lib/jenkins/workspace/postgis/branches/2.1/raster/test/regress'
make[2]: *** [check] Error 2
make[2]: Leaving directory
`/var/lib/jenkins/workspace/postgis/branches/2.1/raster/test'
make[1]: *** [check] Error 2
make[1]: Leaving directory
`/var/lib/jenkins/workspace/postgis/branches/2.1/raster'
error is unfortunately not terribly helpful
I'll rerun again to make sure not some fluke of nature.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2826>
