[postgis-tickets] [PostGIS] #2827: After 2.0.5 to 2.2.0dev upgrade: ERROR: unrecognized configuration parameter "postgis.backend"
PostGIS trac at osgeo.org
Tue Jul 8 02:21:59 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Running
 make check RUNTESTFLAGS='-v --extension --upgrade-path=2.0.5--2.2.0dev'
 I get the error:
 --- sfcgal/concave_hull_expected        2014-06-25 14:05:55.018274295
 +0200
 +++ /tmp/pgis_reg/test_105_out  2014-07-08 11:18:09.069767628 +0200
 @@ -1,3 +1,4 @@
 +ERROR:  unrecognized configuration parameter "postgis.backend"
 It sounds like the "postgis.backend" GUC parameter is not installed on
 upgrade, but only on new install, can it be ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2827>
