[postgis-tickets] [PostGIS] #2837: ST_Extrude unexpected GeometryType in extrude('Solid')
trac at osgeo.org
Mon Jul 14 01:21:31 PDT 2014
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: sfcgal | Version: trunk
Keywords: |
Comment(by vmo):
We cannot extrude solids in SFCGAL at the moment.
I'm not sure I ever did that in CAD (which I used to use quite a lot), I'm
not even sure if any CAD system will allow you to.
I can imagine how to perform the operation:
- split the solid along the line that defines the shadow figure of the
solid on a plane normal to the extrusion direction
- extrude this line
- the result is the combination of this extrusion an the two halves of
the solid
Dealing with holes is a bit complicated though.
I there a use-case ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2837#comment:2>
