[postgis-tickets] [PostGIS] #2249: [raster] Implement ST_MakeEmptyCoverage
trac at osgeo.org
Fri Jul 18 01:30:47 PDT 2014
Reporter: dzwarg | Owner: dzwarg
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: raster |
Comment(by strk):
I've taken a look at the function signature in the latest patch and got a
bit scared :)
I imagine a coverage creation as two steps:
1. Creation of the table that would represent the coverage configuration
2. Population of the coverage
The first step could be similar to AddRasterColumn, that is it only
creates a structure,
w/out inserting the data.
The way I'd call such a coverage-creation function would be by passing it:
Mandatory:
1. The spatial extent to be covered by the coverage
2. The pixel size in geographical units (the scale)
Optional:
3. SRID. Unconstrained if not given. [ok, maybe this could be mandatory]
4. The max size of coverage tiles in pixels. Unconstrained if not given.
I see this function instead creates a whole set of empty tiles,
which is possibly a big waste of time as you probably want to later modify
those tiles to have actual data in them...
Also for a big coverage it could be very easy to end up out of memory.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2249#comment:5>
