[postgis-tickets] [PostGIS] #2814: address_standardizer does not install with all encodings of database
PostGIS trac at osgeo.org
Tue Jul 22 17:21:14 PDT 2014
  Reporter:  robe                 |       Owner:  woobri
      Type:  defect               |      Status:  closed
  Priority:  high                 |   Milestone:  PostGIS 2.2.0
 Component:  pagc_address_parser  |     Version:  trunk
Resolution:  fixed                |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Problem seems to be in the .control file.  The line had
 encoding = 'LATIN1'
 I read here http://www.postgresql.org/docs/current/static/extend-
 extensions.html seems that's only useful if your script file has non-ASCII
 characters.  This may be the case when we get to dataset extensions but
 doesn't seem relevant for the actual address_standardizer extension
 itself.
 Committed at r12820
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2814#comment:1>
