[postgis-tickets] [PostGIS] #2854: travis failing regress
trac at osgeo.org
Thu Jul 24 15:25:29 PDT 2014
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: buildbots | Version: 2.1.x
Keywords: |
Travis has been failing regress since my #899 commits, but the errors
don't seem to be breaking any where there so might be something unrelated.
Errors from travis
Error encountered loading /home/travis/build/postgis/postgis/regress/00
-regress-install/share/contrib/postgis/postgis.sql, see
/tmp/pgis_reg/regress_log for details
make[1]: *** [check] Error 3
make[1]: Leaving directory `/home/travis/build/postgis/postgis/regress'
make: *** [check] Error 1
The command "make test" exited with 2.
https://travis-ci.org/postgis/postgis/builds/30795197
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2854>
