[postgis-tickets] [PostGIS] #2850: Preserve scale and precision when generating shape file with pgsql2shp
trac at osgeo.org
Fri Jul 25 06:33:46 PDT 2014
Reporter: hopfgartner | Owner: mcayland
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: loader/dumper | Version: 2.1.x
Keywords: pgsql2shp |
Comment(by strk):
With your patch applied, I tried the following:
./pgsql2shp strk "select 1.2345678901234::numeric(12,12)"
The numeric(12,12) form tells PostgreSQL that there are a total of 12
significant digits, and all of them are in the decimal part. Ref:
http://www.postgresql.org/docs/9.1/static/datatype-numeric.html
In output (with your patch), I get (checked with dbfview -e):
Field Name Type Length Decimal Pos
Numeric N 12 12
Numeric : 0.1234567890
You can see the actual value is truncated to 12 _characters_ rather than
significant digits.
Without your patch, I get:
Numeric N 32 10
Numeric : 0.123456789012
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2850#comment:2>
