[postgis-tickets] [PostGIS] #2855: ST_MinkowskiSum gives polyhedral surface invalid error
PostGIS trac at osgeo.org
Fri Jul 25 12:08:18 PDT 2014
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  2.1.x
 Keywords:          |
 I think this is a bug, but just trying out ST_MinkowskiSum to try to
 understand outputs so I may not be using it right
 SELECT ST_MinkowskiSum('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0,
 0 0 0)),
         ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0
 1, 0 0 0)),
         ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
         ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)), ((0 0 1, 1 0 1, 1 1 1, 0 1
 1, 0 0 1)) )'::geometry,
         'POLYGON Z ((0.5 0 0.5,0.5 0 1.5,0.5 1 1.5,0.5 1 0.5,0.5 0
 0.5))'::geometry
 Gives error:
 NOTICE:  During minkowski_sum(A,B):
 NOTICE:    with A: POLYHEDRALSURFACE(((0/1 0/1 0/1,0/1 0/1 1/1,0/1 1/1
 1/1,0/1 1/1 0/1,0/1 0/1 0/1)),((0/1 0/1 0/1,0/1 1/1 0/1,1/1 1/1 0/1,1/1
 0/1 0/1,0/1 0/1 0/1)),((0/1 0/1 0/1,1/1 0/1 0/1,1/1 0/1 1/1,0/1 0/1
 1/1,0/1 0/1 0/1)),((1/1 1/1 0/1,1/1 1/1 1/1,1/1 0/1 1/1,1/1 0/1 0/1,1/1
 1/1 0/1)),((0/1 1/1 0/1,0/1 1/1 1/1,1/1 1/1 1/1,1/1 1/1 0/1,0/1 1/1
 0/1)),((0/1 0/1 1/1,1/1 0/1 1/1,1/1 1/1 1/1,0/1 1/1 1/1,0/1 0/1 1/1)))
 NOTICE:     and B: POLYGON((1/2 0/1 1/2,1/2 0/1 3/2,1/2 1/1 3/2,1/2 1/1
 1/2,1/2 0/1 1/2))
 ERROR:  PolyhedralSurface is invalid : inconsistant orientation of
 PolyhedralSurface detected at edge 2 (3-3) of polygon 4 :
 POLYHEDRALSURFACE(((0/1 0/1,0/1 0/1,0/1 1/1,0/1 1/1,0/1 0/1)),((0/1
 0/1,0/1 1/1,1/1 1/1,1/1 0/1,0/1 0/1)),((0/1 0/1,1/1 0/1,1/1 0/1,0/1 0/
 ********** Error **********
 SQL state: XX000
 I'm using sfcgal 1.0.4
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2855>
