[postgis-tickets] [PostGIS] #2861: PostGis Topology performance improvements : index on containing_face
trac at osgeo.org
Wed Jul 30 03:51:16 PDT 2014
Reporter: remic | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone:
Component: topology | Version: 2.1.x
Keywords: |
The idea is to put a simple btree index on node.containing_face at table
creation
The index would be used in
_the "intersects" function (case of point/polygon) "'WHERE ... AND
r2.element_id = n.containing_face" '"
_the addface function ''WHERE containing_face IS NOT NULL"
_ the ST_RemEdgeNewFace function " -- Update containing_face for all
nodes still referencing old faces"
_the ST_RemEdgeModFace function " -- Update containing_face for all
_ the _ST_AddFaceSplit function " -- Update isolated nodes in new new
face "
I think there is significant evidence that such an index will be used.
My usage of topology is very limited (I only use edge topo) and I don't
have the benchmark to prove that such index would speed the operations.
If somebody uses face/node, it should be simple to benchmark : drop
topology, create topology, create index, import data in topology .
Then a simple look on index stats should tell if it was used ans how much.
However :
_the above function will obviously be speeded.
_index are mandatory on primary key (postgres default), this should be the
same for "simple" foreign key
_ the basic btree index is very low cost (time & memory)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2861>
