[postgis-tickets] [PostGIS] #2838: Finish up X3D implementation for all types
trac at osgeo.org
Thu Jul 31 05:52:05 PDT 2014
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
actually collections aren't quite handled. I'm just outputting them by
recursing, but technically each should be wrapped in a shape and then
grouped. That deviates from the model I have for the others. I'm
thinking of using the switch (which currently is 0) to denote if x3d
should output with shape / grouping tags or just always output collections
that way. Other options will include whether to use regular coordinates
or X3D geocoordinates.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2838#comment:3>
