[postgis-tickets] [PostGIS] #2989: Debbie failing on interrupt test
PostGIS trac at osgeo.org
Tue Nov 11 02:07:52 PST 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Sorry, r13124 will not pass make check due to unrelated change in r13123.
 Things should be fine with r13125.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2989#comment:6>
