[postgis-tickets] [PostGIS] #3234: ST_AddIsoNode allows adding an EMPTY point to the topology
PostGIS trac at osgeo.org
Fri Aug 7 00:09:40 PDT 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 it takes passing NULL as the containing_face, or a check for containment
 results in a failure (not within face)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3234#comment:3>
