[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Mon Aug 10 11:29:26 PDT 2015
"postgis.backend"
  Reporter:  robe                   |      Owner:  pramsey
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Changes (by pramsey):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 You haven't really solved the problem, you've just ducked it a different
 way. It seems pretty trivial to exercise,
 foo=# create extension postgis with version '2.1.8';
 CREATE EXTENSION
 foo=# alter extension postgis update to '2.2.0dev';
 foo=#
 As long as you CREATE and ALTER in the same session you have both
 libraries loaded at once. In fact, if you do *anything* PostGIS-related
 with your session once you connect and before you ALTER, you'll end up
 with the problem. Why not retain the test to let existing GUCs survive
 during init? (r12351)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2382#comment:38>
