[postgis-tickets] [PostGIS] #3227: Support for Tiger 2015
trac at osgeo.org
Sun Aug 16 15:02:08 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: reopened
Priority: high | Milestone: PostGIS 2.2.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment (by robe):
The tables/lookup.. part hasn't changed. It get's run as part of the
create_geocode.sql and that sets the search path to tiger, so having to do
tiger.state should not be necessary.
Now why you are getting the above error is a complete mystery to me. Do
you get the same issues if you install tiger geocoder via extensions with
CREATE EXTENSION postgis_tiger_geocoder;
I was thinking of getting rid of the manual scripts since for PostGIS 2.2,
we only support PostgreSQL 9.1+, and the manual script is just one more
set of things I got to worry about and test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3227#comment:10>
