[postgis-tickets] [PostGIS] #3227: Support for Tiger 2015
trac at osgeo.org
Sun Aug 16 15:17:47 PDT 2015
Reporter: robe | Owner: robe
Type: enhancement | Status: reopened
Priority: high | Milestone: PostGIS 2.2.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Brian,
On second thought, I guess just in case users have another state table in
their search path, probably a good idea to schema qualify all these
tables. I don't plan on changing the schema from tiger for a while so
that seems safe.
Now regarding your issue above, I just tried reloading my state and works
fine (though perhaps you have another state table and its inheriting from
the wrong one).
Here is my output for compare:
c:\gisdata\ftp2.census.gov\geo\tiger\TIGER2015\STATE>"C:\Program
Files\7-Zip\7z.exe" e
c:\gisdata\ftp2.census.gov\geo\tiger\TIGER2015\STATE\tl_2015_us_state.zip
-o\gisdata\temp\
7-Zip [64] 9.38 beta Copyright (c) 1999-2014 Igor Pavlov 2015-01-03
Processing archive:
Extracting tl_2015_us_state.cpg
Extracting tl_2015_us_state.dbf
Extracting tl_2015_us_state.prj
Extracting tl_2015_us_state.shp
Extracting tl_2015_us_state.shp.ea.iso.xml
Extracting tl_2015_us_state.shp.iso.xml
Extracting tl_2015_us_state.shp.xml
Extracting tl_2015_us_state.shx
Everything is Ok
Files: 8
Compressed: 8780814
Kernel Time = 0.000 = 0%
User Time = 0.156 = 91%
Process Time = 0.156 = 91% Virtual Memory = 2 MB
Global Time = 0.170 = 100% Physical Memory = 5 MB
c:\gisdata\ftp2.census.gov\geo\tiger\TIGER2015\STATE>cd \gisdata\temp\
c:\gisdata\temp>"C:\ming64gcc48\projects\postgresql\rel\pg9.4w64gcc48edb\bin\psql"
-c "CREATE TABLE tiger_data.state_all(CONSTRAINT pk_state_all PRIMARY KEY
(statefp),CONSTRAINT uidx_state_all_stusps UNIQUE (stusps), CONSTRAINT
uidx_state_all_gid UNIQUE (gid) ) INHERITS(state); "
CREATE TABLE
c:\gisdata\temp>"C:\ming64gcc48\projects\postgresql\rel\pg9.4w64gcc48edb\bin\shp2pgsql"
-D -c -s 4269 -g the_geom -W "latin1" tl_2015_us_state.dbf
tiger_staging.state |
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
SET
SET
BEGIN
CREATE TABLE
ALTER TABLE
addgeometrycolumn
tiger_staging.state.the_geom SRID:4269 TYPE:MULTIPOLYGON DIMS:2
(1 row)
COPY 56
COMMIT
ANALYZE
-c "SELECT loader_load_staged_data(lower('state'), lower('state_all')); "
NOTICE: INSERT INTO
tiger_data.state_all(region,division,statefp,statens,stusps,name,lsad,mtfcc,funcstat,aland,awater,intptlat,intptlon,the_geom)
SELECT
FROM tiger_staging.state;
CONTEXT: SQL function "loader_load_staged_data" statement 1
56
(1 row)
-c "CREATE INDEX tiger_data_state_all_the_geom_gist ON
tiger_data.state_all USING gist(the_geom);"
CREATE INDEX
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3227#comment:11>
