[postgis-tickets] [PostGIS] #3254: ST_SubDivide garden crash, not empty safe
PostGIS trac at osgeo.org
Fri Aug 21 00:07:35 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> SELECT ST_Subdivide(ST_GeomFromText('POINT EMPTY',4326),3);
> Crash.
New description:
 Crash.
 this is the full garden test
 SELECT ST_Subdivide(foo1.the_geom, 3) As result
                                                         FROM ((SELECT
 ST_GeomFromText('POINT EMPTY',4326) As the_geom
                         UNION ALL SELECT ST_GeomFromText('MULTIPOINT
                         UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
                         UNION ALL SELECT ST_GeomFromText('LINESTRING
                         UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
 EMPTY',4326) As the_geom ) ) As foo1 LIMIT 3;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3254#comment:1>
