[postgis-tickets] [PostGIS] #3254: ST_SubDivide garden crash, not empty safe
trac at osgeo.org
Fri Aug 21 00:08:31 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> SELECT ST_Subdivide(ST_GeomFromText('POINT EMPTY',4326),3);
> Crash.
> this is the full garden test
> SELECT ST_Subdivide(foo1.the_geom, 3) As result
> FROM ((SELECT
> ST_GeomFromText('POINT EMPTY',4326) As the_geom
> UNION ALL SELECT ST_GeomFromText('MULTIPOINT
> UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
> UNION ALL SELECT ST_GeomFromText('LINESTRING
> UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
> EMPTY',4326) As the_geom ) ) As foo1 LIMIT 3;
New description:
Crash.
FROM ((SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3254#comment:2>
