[postgis-tickets] [PostGIS] #3253: ST_3DMaxDistance curved geometries mixed dimension yields DIST_MAX mode not supported
trac at osgeo.org
Fri Aug 21 00:34:26 PDT 2015
supported
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
nicklas,
I was testing with:
POSTGIS="2.2.0dev r13966" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.9.1,
04 March 2015" GDAL="GDAL 2.0.0, released 2015/06/14" LIBXML="2.7.8"
LIBJSON="0.12" RASTER
When I run with ST_MaxDistance, it appears to be supported (whether it
gives right answer is another question)
SELECT ST_MaxDistance('GEOMETRYCOLLECTION Z (MULTIPOLYGON Z (((-71.0821
42.3036 2,-71.0822 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821
42.3036 2))),POLYGON Z ((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257
42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703
1)))'::geometry, 'MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-71.0821
42.3036,-71.4821 42.3036,-71.7821 42.7036,-71.0821 42.7036,-71.0821
42.3036),(-71.1821 42.4036,-71.3821 42.6036,-71.3821 42.4036,-71.1821
42.4036)))'::geometry);
--outputs
0.806349831028689
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3253#comment:2>
