[postgis-tickets] [PostGIS] #3253: ST_3DMaxDistance curved geometries mixed dimension yields DIST_MAX mode not supported
trac at osgeo.org
Fri Aug 21 00:46:35 PDT 2015
supported
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by nicklas):
Ok, thanks
I will try to take a look this evening.
I have :
POSTGIS="2.2.0dev r13114" GEOS="3.5.0dev-CAPI-1.9.0 r4026" PROJ="Rel.
4.9.0, 27 October 2013" GDAL="GDAL 1.11dev, released 2013/04/13"
LIBXML="2.8.0" LIBJSON="0.11.99" RASTER
and the error message I get from the query below is quite strange(but
apparently outdated):
select st_MaxDistance('point(1 1)'::geometry, 'circularstring(1 1, 2 2, 2
1)'::geometry);
It says:
ERROR: Exception in LWGEOM2GEOS: curved geometry not supported.
Why it is tried converted to GEOS format is more than I understand.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3253#comment:3>
