[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
PostGIS trac at osgeo.org
Sat Aug 22 09:13:06 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by dbaston):
 Sorry robe, I just saw this....
 The first thing I would check is whether the correct tolerance distance is
 making it to where it's needed at line 164 of lwgeom_geos_cluster.c.
 I would work on this myself if I had a Windows build environment set
 up....you don't have anything I could RDP into, do you?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3220#comment:8>
