[postgis-tickets] [PostGIS] #3184: Regression tests for address_standardizer
trac at osgeo.org
Sat Aug 22 12:37:36 PDT 2015
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: pagc_address_parser | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Committed at r13972 to use the postgresql pgconfig installcheck machinery.
I'm not sure how to trigger it as part of our battery of tests, and
perhaps it shouldn't since it won't work if not installed. (and given most
of our other tests work without installation, probably best to leave it
like this for now) and document how to test in docs.
cd extensions/address_standardizer
make installcheck
I changed winnie's regress script to do the above.
I'll close this ticket once I've put steps in installation docs section
and cleaned up tests so not failing on winnie.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3184#comment:2>
