[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
trac at osgeo.org
Sat Aug 22 14:24:51 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
dbaston,
I'll check this out. Sadly no this issue only happens on windows desktop
when testing against mingw PostgreSQL. On winnie I have her testing
against VC++ builds, where this issue doesn't show, which is why I'm not
so concerned if others aren't experiencing it. I'll checkout that line
you mentioned and see what's happening there (after I get other tickets
squared away).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3220#comment:9>
