[postgis-tickets] [PostGIS] #3268: pgsql2shp: wrong ldid in dbf
trac at osgeo.org
Sat Aug 29 12:11:34 PDT 2015
Reporter: Redoute | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.1.x
Keywords: pgsql2shp |
I have a database with ENCODING = 'UTF8' LC_COLLATE =
'German_Germany.1252' LC_CTYPE = 'German_Germany.1252'. When I export a
table with pgsql2shp, the dbf file contains text attributes encoded in
UTF-8, which is fine. But the language identifier (ldid byte at position
29 of the dbf) is set to 0x57, meaning codepage 1252 ANSI.
I tried pgsql2shp in Windows 8, both as subprocess call in python 3 and at
the command line. pgsql2shp RELEASE: 2.1.5 (r13152).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3268>
