[postgis-tickets] [PostGIS] #3268: pgsql2shp: wrong ldid in dbf
PostGIS trac at osgeo.org
Sat Aug 29 17:06:14 PDT 2015
  Reporter:  Redoute  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.1.9
 Component:  postgis  |    Version:  2.1.x
Resolution:           |   Keywords:  pgsql2shp
Comment (by pramsey):
 It looks like the shape driver just writes that ldid in by default, and
 then the libpq library just hauls the data down in the server encoding.
 The problem is a little aggravated by GDAL now considering LDID/87 to mean
 WIN1252. A partial workaround could be to set your PGCLIENTENCODING
 environment variable to WIN1252, so your data at least match your LDID.
 Probably we should be setting the LDID to "UTF-8" so that at least GDAL
 will interpret the data right (and hence hopefully QGIS too)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3268#comment:1>
