[postgis-tickets] [PostGIS] #2918: Use GeographicLib functions for ST_Azimuth, ST_Distance, ST_Project, ST_Length, ST_Perimeter and ST_Area
trac at osgeo.org
Thu Feb 5 14:01:03 PST 2015
Reporter: mwtoews | Owner: pramsey
Type: patch | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by karney):
As the author of GeographicLib, I am not a disinterested observer; so
treat the following comments in this light...
I recommend using the GeographicLib routines for all geodesic
calculations rather than a hybrid of legacy code (presumably Vincenty)
and GeographicLib. The reasons are:
(1) Improved accuracy. Vincenty is pretty accurate (the error is about
0.1 mm). However this error can by magnified in certain circumstances
(a poorly conditioned triangulation, for example). GeographicLib gives
full double-precision accuracy.
(2) Solution to the inverse problem is always found. Vincenty fails in
a small fraction of cases which means that all callers of the inverse
routines need to handle a possible failure.
(3) GeographicLib calculates differential quantities related to
geodesics. These are useful in solving some problems, e.g., computing
the time of closest approach for two vessels moving along geodesics.
(4) Smaller library size. To calculate the area you need to pull in the
GeographicLib routines anyway. It make sense to dispense with the (now
redundant) code.
(5) Consistency. In the case where there are multiple shortest
geodesics, it is important that the area reported apply to the geodesic
which is found. This is difficult to do with the hybrid approach.
This just leaves the issue of the times. Most likely this is not a key
issue since the times are so small -- roughly equivalent to performing a
map projection. (In any case, many users would trade a more accurate
and robust solution for a little speed.) The comparative times for
randomly sampled points reported in my paper (Sec. 7) are:
Vincenty GeographicLib
direct 1.11 us 0.88 us
line 0.37 us
inverse 1.34 us 2.34 us
The time reported for "line" is the time per point to compute several
points along a single geodesic (duplicating this functionality with
Vincenty is straightforward but typically isn't provided).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2918#comment:21>
