[postgis-tickets] [PostGIS] #1110: Saint Paul vs. St. Paul
trac at osgeo.org
Thu Feb 5 21:27:06 PST 2015
Reporter: mikepease | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS Future
Component: tiger geocoder | Version: 1.5.X
Keywords: |
Comment(by mattybe):
Thanks, Steve. I also found a workaround following the advice you gave
here: http://lists.osgeo.org/pipermail/postgis-
users/2014-April/039096.html
spatial=# select (addy).*, g.rating from geocode('200 East Washington
Street, Indianapolis, IN 46204') as g;
address | predirabbrev | streetname | streettypeabbrev | postdirabbrev |
internal | location | stateabbrev | zip | parsed |
rating
200 | E | Washington | St | |
| Indianapolis city (balance) | IN | 46204 | t | 15
300 | E | Washington | St | |
| Indianapolis city (balance) | IN | 46202 | t | 24
spatial=# CREATE TABLE tiger_data.IN_place_add(CONSTRAINT pk_IN_place_add
PRIMARY KEY (plcidfp) , CONSTRAINT chk_statefp CHECK (statefp::text =
'18'::text)) INHERITS(place);
spatial=# insert into tiger_data.IN_place_add select * from place where
name like 'Indianapolis%';
spatial=# update tiger_data.IN_place_add set name='Indianapolis',
namelsad='Indianapolis';
spatial=# SELECT install_missing_indexes();
internal | location | stateabbrev | zip | parsed | rating
| Indianapolis | IN | 46204 | t | 0
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1110#comment:12>
