[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
trac at osgeo.org
Sat Feb 7 17:52:30 PST 2015
Reporter: jeanchristophesaville | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: Management 2.0
Component: postgis | Version: 2.1.x
Keywords: POINT EMPTY , MULTIPOINT EMPTY |
Using version
"POSTGIS="2.1.2 r12389" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
March 2012" LIBXML="2.6.26" LIBJSON="UNKNOWN""
I have a table with a column definition of:
ALTER TABLE "myTable" ADD COLUMN point_as_4326 geometry(Point,4326);
In which I will store 'POINT EMPTY' for invalid point geometries
However when I try and restore a previous dump file to this table I get
the following error.
COPY failed for table "position": ERROR: Geometry type (MultiPoint) does
not match column type (Point)
Upon further investigation I found that my version of PostGIS seems to
produce the same WKB for 'POINT EMPTY' and 'MULTIPOINT EMPTY' which in
turn fails the column validation of geometry(Point,4326);
To demonstrate the problem behaviour:
SELECT ST_GeomFromText('POINT EMPTY') --> producess
'010400000000000000'
SELECT ST_GeomFromText('MULTIPOINT EMPTY') --> producess
SELECT ST_GeomFromText('POINT EMPTY') = ST_GeomFromText('MULTIPOINT
EMPTY') --> produces true
SELECT ST_AsText('010400000000000000') --> produces 'MULTIPOINT
EMPTY' -- I expect 'POINT EMPTY' here
SELECT ST_AsText(ST_GeomFromText('POINT EMPTY')) --> However
produces 'POINT EMPTY'
It seems that there are explicit constants for various empty geometry
types as per the following
SELECT ST_AsText('010200000000000000') --"LINESTRING EMPTY"
SELECT ST_AsText('010300000000000000') --"POLYGON EMPTY"
SELECT ST_AsText('010400000000000000') --"MULTIPOINT EMPTY"
SELECT ST_AsText('010500000000000000') --"MULTILINESTRING EMPTY"
SELECT ST_AsText('010600000000000000') --"MULTIPOLYGON EMPTY"
SELECT ST_AsText('010700000000000000') --"GEOMETRYCOLLECTION EMPTY"
SELECT ST_AsText('010800000000000000') --"CIRCULARSTRING EMPTY"
SELECT ST_AsText('010900000000000000') --"COMPOUNDCURVE EMPTY"
However I'm not sure what happened to "POINT EMPTY" which I haven't come
accross yet
In version
"POSTGIS="1.5.8" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6 March
2012" LIBXML="2.6.26" USE_STATS (procs from 1.5 r5976 need upgrade)"
SELECT ST_GeomFromText('POINT EMPTY') -- produces '010700000000000000' =
All of the above to ask why are we not using an explicit POINT EMPTY value
and how can I get my previous backup restored without failing geometry
type validation.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031>
