[postgis-tickets] [PostGIS] #3035: Errors on pg_restore
trac at osgeo.org
Mon Feb 16 02:38:10 PST 2015
Reporter: iriswind | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
I have a postgresql cluster with installed extension postgis2 and everyday
i run pg_dump for some database:
pg_dump -h 127.0.0.1 -p 5432 -d maindb -U postgres -Fc -Z 6 -f
/dump/out.sql
After that i start restore of my database on test cluster:
pg_restore -h 127.0.0.1 -p 5433 -d maindb_test -Fc -U postgres
/dump/out.sql
and i get errors in pg_logs:
pg_restore: [archiver (db)] Error from TOC entry 6932; 2753 17959 OPERATOR
FAMILY btree_geography_ops postgres
pg_restore: [archiver (db)] could not execute query: ERROR: operator
family "btree_geography_ops" for access method "btree" already exists
Command was: CREATE OPERATOR FAMILY btree_geography_ops USING btree;
Can you help me to solve the problem?
Postgresql details:
"PostgreSQL 9.3.5 on x86_64-unknown-linux-gnu, compiled by gcc (GCC) 4.4.7
20120313 (Red Hat 4.4.7-4), 64-bit POSTGIS="2.1.5 r13152"
GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
1.9.2, released 2012/10/08" LIBXML="2.7.6" LIBJSON= (...)".
With regards,
Pantileenko Denis
system administrator
LLC "Techniology"
irisregit at yahoo.com
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3035>
