[postgis-tickets] [PostGIS] #1224: Provide a topology.ST_ValidateTopology as per ISO specs
PostGIS trac at osgeo.org
Tue Feb 17 07:06:33 PST 2015
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by remic):
 I don't know if it is in the spec,
 but ValidateTopology doesn't check edge-linking (that is, that for each
 edge, next_left_edge and next_right_edge are correct).
 We could use a function I wrote on the whole topology:
 rc_RecomputeEdgeLinking(topology_name TEXT, nodes_to_update INT[] ).
 If it returns something, it means there were errors (that were corrected).
 I'm not sure either that ValidateTopology check that left_face and
 right_face are correctly set.
 Rémi-C
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1224#comment:5>
