[postgis-tickets] [PostGIS] #3046: topology.GetRingEdges return wrong ring when edge.next_left/right = edge
trac at osgeo.org
Fri Feb 20 04:35:12 PST 2015
Reporter: remic | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone:
Component: topology | Version: 2.1.x
Resolution: invalid | Keywords:
Comment(by remic):
Again I strongly disagree.
Of course you walk on the edge side, this is precisely why walking from
-N or +N shouldn't give the same result (the sign change the direction of
edge).
So even when walking always to the left, you should have different
results.
In fact, our data structure is a disguised half-edge.
When you have the correct ring, it is easy to find which edges are
"isolated" (that is next_left_edge or next_right_edge = edge_id), it is
simply the edge that are present with both sign in the ring.
CHeers,
Rémi-C
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3046#comment:5>
