[postgis-tickets] [PostGIS] #3046: topology.GetRingEdges return wrong ring when edge.next_left/right = edge
trac at osgeo.org
Mon Feb 23 00:27:05 PST 2015
Reporter: remic | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone:
Component: topology | Version: 2.1.x
Resolution: invalid | Keywords:
Comment(by strk):
Sign does not only change direction but also side. You walk forward on the
left side, backward on the right side. This is by design.
The only way to change direction would be to walk backward on the left
side or forward on the right side.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3046#comment:6>
