[postgis-tickets] [PostGIS] #3011: ST_EstimatedExtent return a incorrect extent value
PostGIS trac at osgeo.org
Wed Jan 7 20:06:31 PST 2015
 Reporter:  rockyc              |       Owner:  pramsey
     Type:  defect              |      Status:  new
 Priority:  medium              |   Milestone:
Component:  postgis             |     Version:  2.1.x
 Keywords:  ST_EstimatedExtent  |
 I have a table, and do the following testing.
 1. Execute sql:
  vacuum analyze st_estimatedextent_test
 2. Execute the sql:
  select ST_EstimatedExtent('public','st_estimatedextent_test','geom');
 Get the result:
  BOX(96.6659851074219 -32.3140754699707,129.162185668945
 -10.3033857345581)
 3. reinsert a existing row by executing the sql:
  insert into st_estimatedextent_test select gid,geom from
 st_estimatedextent_test where gid = 1;
 4. Execute sql
  vacuum analyze st_estimatedextent_test;
 5. Execute the sql
 Get the result:
  BOX(105.510528564453 -32.3140754699707,129.118179321289
 -10.3033857345581)
 I think the correct result should be:
 -10.3033857345581), returned in the step 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3011>
