[postgis-tickets] [PostGIS] #3011: ST_EstimatedExtent return a incorrect extent value
trac at osgeo.org
Sun Jan 11 23:30:33 PST 2015
Reporter: rockyc | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: ST_EstimatedExtent |
Comment(by rockyc):
Replying to [comment:3 pramsey]:
> The estimate is based on a sample. Changing the rows changes which
subset gets picked for the sample, getting a smaller box is not
unreasonable.
You means, its results is only based on a sample, and can be changed
dramatically dependent on the picked sample.
If I understand correctly, does it mean, sometimes, the return box is
smaller than the value return from ST_Extent, and sometimes is larger, and
also, the difference between ST_EstimatedExtent and ST_Extent can be a big
value, right?
If it is true, do you have some guidance on when,where and how to use
ST_EstimatedExtent.
Thanks
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3011#comment:4>
