[postgis-tickets] [PostGIS] #2573: Have ST_3DIntersects to recognize Triangle as a type
PostGIS trac at osgeo.org
Tue Jan 20 22:46:09 PST 2015
 Reporter:  smathermather  |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.2.0
Component:  documentation  |     Version:  2.1.x
 Keywords:                 |
Comment(by robe):
 I was just wondering if we should have a Solid / MultiSolid type similar
 to what I think Oracle has
 http://docs.oracle.com/database/121/SPATL/sdo_intro.htm#SPATL468
 Though that might be a major undertaking so probably best to table till
 2.3
 Regarding the ST_IsSolid patch where is that or are you still preparing
 it?  Might as well also add an ST_SetSolid(geometry,boolean) if not too
 much trouble that allows you to set and unset that bit, but does
 validation to insure it is a closed surface and errors if it's not.
 I think for people running versions of SFCGAL lower than 1.1, we can just
 return a NOT implemented message similar to what we do if someone calls a
 geojson function and they did not compile with JSON support.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2573#comment:10>
