[postgis-tickets] [PostGIS] #3008: pgsql2shp version 2.1.4 crash
trac at osgeo.org
Wed Jan 21 08:56:05 PST 2015
Reporter: nap2000 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: pgsql2shp |
Comment(by robe):
nap2000,
I tried the table you had and exported using 2 windows boxes I have and
couldn't trigger a crash using the below command. I do have an Ubuntu
14.04 box I can try on, but I need to upgrade that since its running 2.1.3
which you say works. Have you tried upgrading to 2.1.5?
Also can you paste in the output of:
select postgis_full_version() || ' ' || version();
pgsql2shp -f c:/test -h localhost -p 5439 -u postgres -P whatever mygisdb
s1_main
I tried on these two
POSTGIS="2.1.5 r13152" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
LIBJSON="UNKNOWN" TOPOLOGY RASTER PostgreSQL 9.4.0, compiled by Visual C++
build 1800, 64-bit
as well as
POSTGIS="2.2.0dev r13180" GEOS="3.5.0dev-CAPI-1.9.0 r4038" SFCGAL="1.0.5"
PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
LIBXML="2.7.8" LIBJSON="0.12" TOPOLOGY (topology procs from "2.1.5 r13152"
need upgrade) RASTER PostgreSQL 9.4.0, compiled by Visual C++ build 1800,
64-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3008#comment:5>
