[postgis-tickets] [PostGIS] #3008: pgsql2shp version 2.1.4 crash
trac at osgeo.org
Wed Jan 21 12:24:20 PST 2015
Reporter: nap2000 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: pgsql2shp |
Comment(by nap2000):
Hi Robe,
I was wrong when I said the problem occurred with a new postgis version.
Its the specific query and as you can see below it looks like postgis
2.1.2.
1) select postgis_full_version() || ' ' || version();
POSTGIS="2.1.2 r12389" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3.5 on x86_64-unknown-linux-gnu,
compiled by gcc (Ubuntu 4.8.2-19ubuntu1) 4.8.2, 64-bit
(1 row)
2) If I remove arbitrary columns from the query then the crash does not
happen. However it does not appear to be a specific column that is
causing it. I am attaching a file with the full query that crashes and a
smaller query that does not.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3008#comment:7>
