[postgis-tickets] [PostGIS] #3008: pgsql2shp version 2.1.4 crash
trac at osgeo.org
Thu Jan 22 14:09:32 PST 2015
Reporter: nap2000 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: pgsql2shp |
Comment(by robe):
Okay I tried the crashing one on my 2.2.0 seems to work fine. Didn't try
on my 2.1.5 but nothing between 2.2.0 and 2.1.5 has changed.
Any chance you can upgrade to see if the issue goes away. Your issue
sounds like #1008 but that was fixed a while ago. Can you verify the
version of pgsql2shp you are running?
Just run pgsqlshp without any args. Just want to rule out you are using an
old version that had the too many columns issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3008#comment:8>
