[postgis-tickets] [PostGIS] #1926: ST_OffsetCurve creates a strange multi-linestring
trac at osgeo.org
Thu Jan 22 17:26:36 PST 2015
Reporter: lexman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.1.x
Keywords: |
Changes (by jef):
* version: 2.0.x => 2.1.x
Comment:
A more recent and example using simpler geometry - a segment of the offset
line is missing and turns it into a multiline string:
qgis=> select st_astext( st_offsetcurve( st_geomfromtext(
'LINESTRING(436533.041 5755061.11,436420.979 5755061.071,436372.505
5755061.054,436346.382 5755061.045)' ), -0.17 ) );
st_astext
MULTILINESTRING((436420.97894038 5755061.24099999,436533.040940836
5755061.27999999),(436346.381941431 5755061.21499999,436372.504941431
5755061.22399999))
(1 row)
qgis=> select postgis_full_version();
NOTICE: Function postgis_topology_scripts_installed() not found. Is
topology support enabled and topology.sql installed?
POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
LIBJSON="UNKNOWN" (core procs from "2.1.2 r12389" need upgrade) RASTER
(raster procs from "2.1.2 r12389" need upgrade)
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1926#comment:3>
