[postgis-tickets] [PostGIS] #2543: invalid join selectivity error from simple query
trac at osgeo.org
Mon Jun 1 06:18:58 PDT 2015
Reporter: paulfriedman | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment (by remic):
Hit again,
this time witha very simple query,
very few data :
--or
FROM bdtopo_topological.face AS f
, bdtopo_topological.node AS n
WHERE face_id = 0
AND ST_Intersects(n.geom , f.mbr ) = TRUE
I get
"ERROR: invalid join selectivity: 157865408.000000"
, same error for explain, explain analyse, and simple execution.
Tables are classical topological tables.
2630 NULL POINT Z (2016.43602159963 20546.3348600308 0)
bdtopo_topological.face :
0 NULL
bdtopo_topological.edge_data :
890 2630 2630 -890 890 890 890 0 0
LINESTRING Z (2016.43602159963 20546.3348600308 0,1807.01948292597
20559.4718857428 0,1641.08811201422 20509.5039160932 0,1569.43592912051
20433.1377737986 0,1658.05836585747 20356.771631504 0,1841.90278249264
20298.3185349328 0,2018.20486408638 20319.0599562968 0,2064.40166621521
20385.0553879094 0,2059.68770681431 20486.8769109689 0,2016.43712931104
20546.3317239128 0)
Everything is vacuum analyzed.
Select Postgis_full_version();
--POSTGIS="2.2.0dev r12846" GEOS="3.5.0dev-CAPI-1.9.0 r0" PROJ="Rel.
4.8.0, 6 March 2012" GDAL="GDAL 2.0.0dev, released 2014/04/16"
LIBXML="2.8.0" TOPOLOGY RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2543#comment:20>
