[postgis-tickets] [PostGIS] #3146: ST_EffectiveArea possible 32-bit crasher
trac at osgeo.org
Tue Jun 2 22:11:24 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Doing garden crash test on my 32-bit PostgreSQL 9.4 EDB, this crashes
SELECT ST_SetEffectiveArea(foo1.the_geom, 20.1, 5) As result
FROM ((SELECT
ST_GeomFromText('LINESTRING(1 2, 1 2)',4326) As the_geom
UNION ALL SELECT ST_MakeLine('SRID=4326;POINT(1
2)'::geometry, 'SRID=4326;POINT EMPTY'::geometry) As the_geom ) ) As foo1
LIMIT 3;
It might just be a 32-bit crasher on my 9.5 instance works okay, but I
haven't tested against 64-bit 9.4 EDB install to be sure it's not a
VC/mingw64 thing.
My 64-bit install is also a bit older. This I tested under:
POSTGIS="2.2.0dev r13601" GEOS="3.5.0dev-CAPI-1.9.0 r4054" PROJ="Rel.
4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
LIBXML="2.7.8" LIBJSON="0.12" RASTER;PostgreSQL 9.4.2, compiled by Visual
C++ build 1800, 32-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3146>
