[postgis-tickets] [PostGIS] #3147: [raster] raster2pgsql should check that the resulting table name it's a valid SQL name.
PostGIS trac at osgeo.org
Wed Jun 3 12:12:05 PDT 2015
valid SQL name.
 Reporter:  tinproject    |      Owner:  dustymugs
     Type:  defect        |     Status:  new
 Priority:  low           |  Milestone:  PostGIS 2.1.8
Component:  raster        |    Version:  2.1.x
 Keywords:  raster2pgsql  |
 For example, executing:
 raster2pgsql 0457h30.tif | psql -d "db" -h "host" -U "user" -W
 ends with a table named 0457h30 on the database. That name it's not a
 valid PostgreSQL table name so a "SELECT * FROM 0457h30;" will fail, also
 a "DROP TABLE 0457h30;" fails too.
 Tested with raster2pgsql RELEASE: 2.1.7 GDAL_VERSION=111 (r13414) on
 Windows.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3147>
