[postgis-tickets] [PostGIS] #3133: ND-Distance function for KNN <<->> support
trac at osgeo.org
Thu Jun 4 06:41:50 PDT 2015
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: closed
Priority: critical | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by pramsey):
Good, don't bother testing M in case we want to change it. As it stands
the behaviour is hard to describe in terms of KNN (if your coordinates are
lon/lat then your nearest distance will be heavily affected by the M, if
your coordinates are in something projected, the nearest distance will be
more likely to be spatially determined). Maybe it's best to just ignore
M/T entirely for the KNN op.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3133#comment:5>
