[postgis-tickets] [PostGIS] #2287: --enable-debug builds are way too verbose
PostGIS trac at osgeo.org
Thu Jun 4 11:44:37 PDT 2015
  Reporter:  alvherre  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  high      |  Milestone:  PostGIS 2.2.0
 Component:  postgis   |    Version:  trunk
Resolution:  fixed     |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 OK, moved debug messages into the DEBUG channel so they can be turned up
 or down using client_min_messages. You still only get as many messages as
 you build for, and all debugging is still macro'ed off for any level < 1.
 At r13617.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2287#comment:5>
