[postgis-tickets] [PostGIS] #3154: make dist should generate the pom.xml
PostGIS trac at osgeo.org
Tue Jun 9 15:05:41 PDT 2015
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.1.8
Component:  postgis  |    Version:  2.1.x
 Keywords:           |
 We recently changed the build -- evidentally around Marchish since that is
 when debbie's jdbc jar builder broke.
 In fixing it up, I realized our make dist does not generate the pom.xml
 and trying to get it is a bit of a pain, since I think it requires running
 the whole configure process (unless you want to manually mess with the
 files).
 I'm going to revise to build as part of the make dist process.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3154>
