[postgis-tickets] [PostGIS] #3156: lwgeom_set_handlers changed signature
trac at osgeo.org
Wed Jun 10 01:21:10 PDT 2015
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
r13617 (June 4 2015) changed the signature of lwgeom_set_handlers.
This is a breaking change, not backward compatible, and should be
reverted.
The way to add handlers to the context should be by using another function
instead.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3156>
