[postgis-tickets] [PostGIS] #3160: make_dist.sh error: cd: can't cd to postgis-dev/java/jdbc
trac at osgeo.org
Fri Jun 12 12:07:54 PDT 2015
Reporter: strk | Owner: robe2
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I reverted by change (I think) at least the make dist part at r13667 (I
think). I can't test because make_dist.sh assumes you can run configure
without any args, and I need args.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3160#comment:1>
