[postgis-tickets] [PostGIS] #3165: make_dist.sh should allow for custom configure
PostGIS trac at osgeo.org
Fri Jun 12 12:32:29 PDT 2015
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS Future
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Right now whenever I make a change to make_dist.sh I can't test it cause
 all my dependencies are in custom locations passed in via
 ./configure
 make_dist.sh just calls configure though.
 Debbie has the same issue, so have a custom make_dist for her.
 It would be nice if make_dist was either smart enough to use what was
 used, or allow for passing in of args
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3165>
